Re: 17BII Fail Message - Need help interpreting Message #3 Posted by Randy Sloyer(US) on 1 Dec 2002, 12:42 a.m., in response to message #1 by Steve
Once the KBD message appears, did you press each key in sequence? You start from the top left, press the 6 top row keys in order, left to right and repeat for each row below. If you press a key out of sequence or you have a bad key, you will see the message you describe.
The message of KBD 02501 indicates it is the "+" key that is faulty. If your "+" key works, you probably pressed the "+" key when the self test was expecting something else.
