Re: Help! HP-41CX Programing Message #2 Posted by Vieira, Luiz C. (Brazil) on 17 Nov 2002, 10:51 a.m., in response to message #1 by Gordon Dyer
Hi, Gordon;
One option is using synthetic programming, say, you enter any character in there, then you substitute it for another by using synth comands. Also, you can save it in the extended memory and use functions available in modules such HEPAX, CCD and others that allow direct manipulation of fikles. Another way that needs extra equipment is downloading the program (HPIL) to a file in your computer, change the code in there and load it back.
Except for the synthetic code (I do not know how to do it, but I have once used synth programming in... 1987?) or the extra functions available in some modules, I cannot think of an easy way to type a non-standard character as a program line.
Cheers.
