Re: Ebay item...manual only, but anyone ever seen the module? Message #8 Posted by db(martinez,california) on 11 Nov 2002, 9:34 p.m., in response to message #7 by Chris Catotti (Florida)
peter;
my co op 41 surveying module calls itself rom #10 and the particular instrument module which i have, that also contains the alignment/offset and vertical curve programs, calls itself rom #12. i believe that the sunshooter was a more general and stand alone set of programs and was not intended to work with mine or the plotter module. mine are both dated 1986 and require a cx to function.
you are right; no code can be stored in the data collector but the programs were pretty complete, and only occasionally clunky, so you had 2.2k for what little extra you needed. data storage in extended is 299 points. the d. c. that you have could store the northing and easting for 4606 points, less if you want elevations, a raw data file, or a note/descripter. so maybe minus a bit but plus whatever was in extended. i kept my control file in extended.
one of the coolest things about the co op is that you can send data files straight from extended to mass storage. if someone gets the book i'll see if i can print out a program or two so you can key it in and play with it.
btw: have you seen tds/co.cp.'s new handheld? coke bottle shape like a husky in a dam near bullet proof body with a multi line touch screen and keys that feel like a new 41. if any new handheld could be described as sexy....
- d
