Re: HP38C Battery Polarity Message #3 Posted by David Smith on 26 Oct 2002, 3:29 p.m., in response to message #1 by Larry Corrado
When installing batteries in a Spice series machine, place a strip of ribbon or paper around the pack to make removing it easier. These machines have a tendency for the battery pack to damage the battery contacts when you remove them. One thing that likes to happen is the bottom (free) end of the battery clip snags between the top contact of the battery and the seam around it. When you try to pry the battery out, the clip snaps off. Not helped by the tendency of the batteries to corrode in these machines.
