Re: HP48S Message #2 Posted by Vieira, Luiz C. (Brazil) on 16 Oct 2002, 12:33 a.m., in response to message #1 by Howard Jones
Hi;
the plain numbers you see are shown this way when STandarD mode is active. If you change to FIXed decimal places, being the Level 1 contents the number of decimal places in the range 0 to 11, the thousands separators (comma or period, depends on which is the radix mark) will appear. There are no thousands separators when STandarD mode is active.
Hope this answers your question.
Cheers.
