Re: Dead HP11C ( Old-HP-Quality beats death ) Message #8 Posted by Vieira, Luiz C. (Brazil) on 27 Oct 2002, 10:06 a.m., in response to message #7 by Erich Neubacher
Hi, Erich;
just for us to be sure about which internals does your 15C have.
Look at the batteries contacts and verify if there are two metal strips, three slices each, or one spring in the positive pole (leftmost) and a small, golden plated tab in the negative pole. If option one is true, you have a flex-circuit assy 15C; if option two is the one (spring + tab), yours is a single PCB model.
Ahead with the difficulties on disassembling, I prefer option two, mostly because circuit stability is better, and repairement is easier. If you need so, I have both types as disassembled stuff, so I can generate some images (no photo camera, just an acceptable scanner) for you to think about it.
Let me know if you want to.
Success. (I also have the Voyagers as "perfect" in many aspects. It seems as if they were designed with pashion. I feel "excited" when using them, and about being sexy... I just did not give my thoughts this sort of freedom of speech. But I agree with you...)
