Re: HP-86 Message #3 Posted by Tony Duell (UK) on 29 Sept 2002, 3:47 p.m., in response to message #1 by Mark Vandemeulebroucke
It's a standard, US scan rate, composite monochrome monitor. Composite just means that the sync signals and video are combined into a single signal, rather than using separate wires for each of them.
Such monitors were very common about 15 years ago (and probably are still made -- they have many applications). If you have a TV that can handle US rates (60Hz vertical, 15750Hz horizontal) and which has a composite (aka 'baseband') input then most likely you can use that. In Europe, there's a composite video input on the SCART connector fitted to just abotu all modern TVs.
