Re: Spot welder for batteries? Message #7 Posted by glynn on 14 Sept 2002, 1:11 a.m., in response to message #6 by Ellis Easley
Ellis:
Took a cursory look at the machine today. It says it is a "Unitek/Miyachi 250 Dual-Pulse Stored Energy Power Supply".
By "250" and "stored energy" I sort of assume that the number is a wattage rating, ie. volts X amps in DC, and some sort of a capacitive-discharge circuit...
And I don't know what voltage, it doesn't say, but it doesn't seem to be high. Like maybe 3-5 volts tops. But 250 divided by 5 would be 50 amps; divided by 3 would be 83.3; that would make a pulse certainly strong enough to melt a spot in light steel or nickel.
The stored schedules in the machine have the following format: Schedule (#__), Pulse 1= (xx)%; Pulse 2=(xx)%; Polarity=(+/-); Width=(Short/Med/Long).
I wish it had more detail onscreen but was Really surprised that it had only those parameters. That the polarity on all the settings I scrolled down was Positive, and the Width setting always "Short" was another surprise; I suppose that since this particular machine was set up for light jobs like battery-packs etc., many of the settings will be only subtly different from each other.
Schedule 1: Pulse 1= 3%; Pulse 2= 9%.
Schedule 2: Pulse 1= 5%; Pulse 2= 15%.
Schedule 3: Pulse 1= 7%; Pulse 2= 22%.
Schedule 4: Pulse 1= 8%; Pulse 2= 26%.
Schedule 5: Pulse 1= 9%; Pulse 2= 28%.
Schedule 6: Pulse 1= 10%; Pulse 2= 11%.
Schedule 7: Pulse 1= 10%; Pulse 2= 30%.
Schedule 8: Pulse 1= 10%; Pulse 2= 35%.
Schedule 9: Pulse 1= 12%; Pulse 2= 36%.
Schedule 10: Pulse 1= 15%; Pulse 2= 35%.
Schedule 11: Pulse 1= 15%; Pulse 2= 40%.
Schedule 12: Pulse 1= 15%; Pulse 2= 45%.
Schedule 13: Pulse 1= 20%; Pulse 2= 45%.
Schedule 14: Pulse 1= 30%; Pulse 2= 50%.
Schedule 15: Pulse 1= 30%; Pulse 2= 65%.
Schedule 16: Pulse 1= 50%; Pulse 2= 77%.
Schedule 17: Pulse 1= 2%; Pulse 2= 4%.
Schedule 18: Pulse 1= 1%; Pulse 2= 5%.
Schedule 19: Pulse 1= .6%; Pulse 2= 0%
And I think there are some dozen more settings on the machine, but that's all I wrote down today.
Say the machine puts out 50A at 100%. That's only .5A per percent, right? So the schedule I use to stick nickel strips onto (AA,N,C,D) batteries with, Schedule 3, kicks out a pulse of 3.5A, then follows with a pulse of 11A. It does so fast enough that you only hear it as one small "thunk".
Well, I still haven't learned much, I know. I will try to follow up with more info-- I am certain that somewhere buried in my bosses office there is an owner's manual. Maybe I can find it...
Ellis, having played with a photo-strobe power-pack, I know it ramped up from a 12v battery to supply some 430v or so, but not many milli-amps-- that's good because while I was measuring it, it bit me. Ouch.
But it should be not terribly hard to do the opposite: a bank of capacitors storing low volts but together punching forth high amps.
Probably the tricky part is to make the only part of the circuit that has, as its highest RESISTANCE to flow through, a junction of pressed-together metals (the intended weld-spot)-- if the legs on the capacitors or the controlling relay have higher resistance than that, it is they that will melt!!
TTYL.-- grh.
