Re: HP 32SII Message #2 Posted by Randy Sloyer on 4 Sept 2002, 8:06 p.m., in response to message #1 by Howard Jones
Anything been spilled on the keyboard? If so, this would be the most likely culprit. The keyboard is scanned by the cpu in 6 columns across and 7 rows down. If it was a bad connection to the cpu board, a whole row or column would be acting up.
What you describe, the loss of just 4 keys in 2 x 2 grid would seem to me to be something in or on the keyboard itself. It is a sandwich of 4 layers of mylar. Two of the layers are spacers with holes, one looks like a double sided pc board but it's made of mylar and the real guts of the keyboard is a single layer sheet that has 37 domes formed in it with conductive material inside the dome. When you press a key, you deform the dome with a snapping motion and the conductive dome bridges a pattern on the circuit underneath, completing the circuit. Any gunk on the dome or the circuit underneath will prevent the circuit from completing. The resistance is very high in these circuits, a minimum of 10k ohm for a completed keypress so it would not take a very thick spill layer to prevent a keyress from registering. Perhaps when you press hard, you are able to burrow past the spill and complete the circuit.
A frequent contributor (Thanks David!) here reports good luck removing the batteries then giving the dirty keyboard three baths in an ultrasonic cleaner with fresh distilled water each time. Shake out as much water as you can, then dry in in an oven on low (< 150F) for several days.
