TTF for the HP41, Voyager and 82143A Message #1 Posted by Vieira, Luiz C. (Brazil) on 25 Aug 2002, 4:23 p.m.
Hi;
I believe some of you (as I do) have been needing TTF files to give a better look to final documents. I posted a few weeks ago a message about an HP41's LCD TTF. Now I added two other TTF and "cleaned" the previous 41's TTF (I removed some trash). I also added an article, that can be seen here. There are links to download the fonts from there.
Hope you can use them.
Best regards.
