Re: aviation pac for 41-CX Message #2 Posted by Les Bell on 20 Aug 2002, 12:27 a.m., in response to message #1 by John Breda
I'm not sure what you're getting at here, John. I still have the Aviation Pac, which I bought in the mid-eighties when I learned to fly. There was no template with the pac, as far as I know - I certainly don't have one now.
The pac doesn't make much use of user-defined keys, since it mostly prompts for input. The exception would be the first program, "Flight Management", which does speed/distance/time/fuel/fuel flow calculations. For that one, the A-E keys represent (and are labelled, when the program starts) D S T FF F respectively.
For the other programs, I guess you could use ASN to assign the starting labels to other keys for faster starting. Is that what you did, with the template to remind you?
Best,
--- Les Bell, CISSP
[http://www.lesbell.com.au]
