Re: HP41 powers off Message #2 Posted by Vieira, Luiz C. (Brazil) on 9 Aug 2002, 12:54 a.m., in response to message #1 by Gary Cox
Hi;
if it goes off while you're typing stuff in, chances are you have an easy-to-beat bad contact in the BATT/IO assy, either between batteries or mainboard. If you have to remove batteris and put them back on, or (don't blame me! Sometimes it is needed...) to squeeze or twist the calculator a bit so it turns on, then you are almost there: just open it and clean it.
If you are not confident about it, wait for some other posts that will guide you to other ways. Read this thread also, because it deals with related stuff.
Success!
