Re: HP 9100B - Shipping from NZ Message #7 Posted by Tony Duell (UK) on 2 Aug 2002, 6:39 p.m., in response to message #6 by David Smith
I would guess the ferrite cores (both in the core-on-a-rope microcode ROM and in the read/write core memory) are brittle (ferrite cores normally are), but I've seen one get broken. I guess they're just properly supported. The light bulbs (to illuminate the register display labels, and for the error indicator) are also fragile, but they're easy to replace. The rest of the machine (apart from the CRT) is _very_ solid.
The CRT is delicate. Not only can the envelope fracture, but also the electron gun is assembled using brittle glaass support rods (inside the CRT envelope). I am told that if these fracture, you can get inter-electrode shorts in the CRT which will damage componets on the deflection boards and on the gating board (and if you're unlucky, on the flip-flop board as well).
Therefore, before powering up an unknown 9100 (particularly one that's been shipped), I'd want to remove the CRT (it's not hard to do), then take off the mu-metal can, and look at the electron gun just to make sure that nothing is broken or shorted.
Incidentally, I've managed to find 2 off 9100Bs and not a single 9100A so far, so for me the 9100B is much the more common machine.
