Re: Help on 17BII's undocumented Let & Get Message #3 Posted by W. Bruce Maguire II on 31 July 2002, 2:09 p.m., in response to message #1 by jianghao
jianghao:
Are you able to purchase the "Museum of HP Calculators CD Set"? Click here:
http://www.hpmuseum.org/cd/cddesc.htm
If you are not able for some reason or other, you might want to contact the owner of this great site, David G Hicks, at:
dgh@hpmuseum.org
and see if you can work out a deal to get the "HP27S/19B Technical Applications" PDF that Ellis mentioned in the prior message. If at all possible, though, please order the full CD set---it is very well worth it!
Bruce.
