Re: more stat ops Message #4 Posted by Andrés C. Rodríguez (Argentina) on 25 July 2002, 5:59 p.m., in response to message #1 by Xtian
The statistics registers can be moved, but in a standard configuration (which I assume you have), are located in memories R11 to R16. There you will find sum of x, sum of x^2, sum of y, sum of y^2, sum of product xy, and number of pairs. All statistics like mean, sdev, etc. are calculated from these values. There are more options which you may enjoy knowing... after your exam! (Good luck!)
BTW, the issue regarding SDEV and Variance has to do with the difference between sample and population. The variance of a sample is larger than the variance of the population, by a factor of ( n /(n-1 )). Sdevs are the square root of variances in both cases. The calculator will give you the sample sdev, so you may need to correct for a population.
Please check all these hints before your exam, since I'm answering just from memory, and there may be small errors in what I recall.
