Re: A couple of HP9810 questions Message #3 Posted by Tony Duell (UK) on 10 July 2002, 6:09 p.m., in response to message #2 by Katie
Thanks for your reply. You see, I have a non-working 9810 on the bench that sometimes decides to do something sane... And when it does, 1/0 does indeed give 9.99999e98 (it was that last digit that worried me -- did I have a register/ALU/firmware problem?). Apparently that's OK.
And yes, the maths ROM behaves as you suggest. None of the LEDs come on at first, then the 'degrees' one comes on when I use a trig function. I will try the Table key next time I have the machine in a state to even try to work :-). I do have the overlay. And I do like those little clips on the ROM module to hang the overlay on to store it. A very neat HP idea :-)
