Re: HP Thermal Printers Message #2 Posted by David Smith on 6 June 2002, 5:21 p.m., in response to message #1 by Juergen Rodenkirchen
Since most non-archival papers are rather acidic and the thermal paper contains chemicals, there is a possibility that over time it could corrode the rather small and delicate print head resistors.
I have seen several machines that sat unused for many years. After cleaning them up and installing new paper, they print just fine for a few lines and then a dot or two in the print head opens up. I have attributed this to corrosion of the resistors in the print head. I don't know if the paper had anything to do with it or not, but it probably did not help.
