Re: DOUBLE SPEED hp49g ? Message #3 Posted by Jonathan Busby on 1 June 2002, 1:46 p.m., in response to message #2 by Tom (UK)
Tom said :
"Yes, they double the clock rate to the CPU with internal modifications, I think the high speed can be turned on and off by the user. I think the higher clock rate is 8MHz - still slow compared to alot of modern stuff."
This is not quite correct. The clock speed is actually only increased from 4 MHz to 6 MHz via a new crystal with a faster clock rate. The calc can be switched from normal to "double-speed" (which is kind of a misnomer it seems) mode by holding down the on key. (they install a small microcontroller I believe)
As far as I know, the maximum speed at which the 48/49 cpu
(actually the Yorke IC) can be clocked at is somewhere around 6 MHz. After that it stops functioning. There are however other ways of overclocking the Yorke that could result in higher achievable speeds and lower power consumption. See http://groups.google.com/groups?hl=en&lr=&selm=kpgmbu0ldjjgkgbfe6it2a6cpcntibleqo%404ax.com&rnum=2 . To the best of my knowledge no one has tried this method though.
Remove the random permutation of "NOSPAM" from my e-mail address before replying.
