41's batteries contacts corroded Message #1 Posted by Vieira, Luiz C. (Brazil) on 10 May 2002, 10:28 a.m.
Hi;
I don’t know if it happens with any 41’s owner, but let’s expose the browse: BAT/IO assy’s oxidation.
Besides the fact that it is hard to find N-size cells in here (rechargeable? NiMH? People haven’t even told about it...), the available ones tend to leak and corrode the terminals, what is by no means desirable.
I am trying to find out a solution for this, if there is one. I am about to wrap the exposed parts of the batteries’ contacts with a thick piece of aluminum paper (what is the actual name for this in English?) but I do not know what sort of chemical reaction would result from this, say, golden-plated copper and aluminum in physical contact. Is there any other procedure to avoid contacts’ corrosion? Can anyone tell me if wrapping the contacts this way will lead to good results?
Thanks for any answer..
