Re: You can do it! Donīt give up now! Message #6 Posted by Vieira, Luiz C. (Brazil) on 11 Apr 2002, 7:10 p.m., in response to message #5 by David Smith
Hi;
well, here in Brazil is somewhat easier to find them. In fact, I was given some O-Rings that were easily found in a (believe me) carīs maintenance garage. They are found in old carburators, as used or replacing, spare O-Rings. I have an 82104A working with two used O-Rings (I just cannot find my cardsī pack... I only have two cards for testing, and they run a lot good) not glued to the axes. Dave, I did not measure the O-Rings, I simply inserted the two (same) that fit in the same measure of the axes (inner and outher limmits). They are still there and running smoothly.
Hope it helps.
Cheers.
