Re: HP-75C pod diagnostic Message #4 Posted by Ellis Easley on 20 Feb 2002, 3:38 a.m., in response to message #1 by Michel
The "pod" probably refers to the 82718A Expansion Pod, an accessory for the 75 which adds a RAM-disk and an intelligent 300 baud modem and some bar code drivers. You install the 75 in the pod semi-permanently (many screws to take it back out). Electrically, the pod plugs into the right ROM port (I think it is this one only because of the mechanical design). What you have is probably a service diagnostic for the pod.
