Re: Questions on HP 41 MLDL Message #2 Posted by Tony Duell on 29 June 2001, 8:40 p.m., in response to message #1 by Juergen Rodenkirchen
The HP41 machine code instructions are 10 bits long (note, it's not strictly microcode IMHO). Most common EPROMs are 8 bits wide, so you can't store an HP41 instruction in a single location of a normal EPROM.
Waht was normally done was to have pairs of EPROMs, The 'L' (lower) one stored the bottom 8 bits of each instruction. The 'U' (upper)
stored the top 2 bits. Noramlly, the 'U' EPROM stored the top 2 bits of 4 instructions packed into a single (8 bit location), so only a quarter as many locations were used in this chip than in the lower one. That's why
the EPROMs are often different sizes (e.g. a 2732 4K chip for the lower bits and a 2716 2K chip (only half of which was used) for the upper bits).
As regards what's in your EPROMS, what happens if you plug it into an HP41 and do a CAT 2? Does it show up at all?
