Re: Programming Instructions for HP49G Message #2 Posted by Daniel Diggelmann on 22 June 2001, 3:59 a.m., in response to message #1 by Chan Tran (IL, USA)
Hi Chan,
Gilberto E. Urroz has written two books about the HP49 which you can buy online at:
http://www.greatunpublished.com/Authors/Gilberto_Urroz.htm
You'll certainly also find some docs about programming here:
http://www.hpcalc.org/
Look also in the HP48 section as the programming hasn't changed. A good book also is the HP48 advanced user's reference manual which is still available from HP.
Cheers Daniel
