Re: HP-25 battery Message #2 Posted by Michael Meyer, M.D. on 14 Nov 2001, 12:18 a.m., in response to message #1 by Seth
Seth,
Getting good battery contact in the Woodstock series calculators can be tricky. Sometime I put a drop of solder on the negative side of the battery so it will stick out as far as the nipple on the positive cell. Also, make sure that the spring is well polished or sanded if you haven't wired the ends of the batteries together on the spring side.
The first step, however, is to see if the calculator has "life". Take two cells already together, in a battery holder case (or a regulated power supply, if you have one, set to 2.4 volts. I have lithium AA cells in my every-day HP-25 that have lasted for months, will store safely for over ten years, and won't leak. They do put out about 3 volts, which can be a little hard on the circuits, so I'm told. I've had no problem with this, and the calculator never needs to be charged.)
Hook up some test leads (alligator clips) to the batteries. With the bottom of the calculator facing up, the positive terminal is on the right (the wider side of the calculator). Hook up the power with tight clips, and wiggle them a little bit for better contact. Try the calculator. If nothing comes on, you have much more restoration to do, if restoration is possible. You can try to carefully sand the terminals with a dremel tool and try the external supply again.
If the calculator works with the external supply, then you need to work on making sure the battery pack makes contact when the springs are extended in the case. Thus, my luck with a small ball of solder on the negative battery face. Tighten the springs, also, by stretching them some.
Let us know how it turns out!! The HP-25 was my first true love. I've never known any other machine so well. If it says "Meyer" on it, it was the one stolen from my locker in high school. Just kidding.
Good luck!
Michael
