Re: 48G Broken Message #2 Posted by Frank Travis on 16 Oct 2001, 11:00 a.m., in response to message #1 by Magda
Your best bet is buying an HP48GX (expandable, 128K RAM, about $150) OR hp48g+ (not expandable, but also has 128K RAM, about $100) from Calcpro website www.calcpro.com. I have purchased from calcpro several times and have talked on many occasions to their manager, Paul Nelson. If you purchase the HP48GX or HP48G+ from Calcpro along with the PC Connectivity kit, you usually get a discounted package deal. My HP48SX (purchased in June or July of 1992 from then Educalc) was having problems turning on about February or March of 1998. I purchased the HP48GX as part of a discounted package deal from Catculating Edge (which replaced Educalc, and has since been replaced by Calcpro). The HP48SX stopped working for good about a couple weeks after I received my HP48GX. My HP48GX is still performing well. I bought an HP48G (not expandable, has 32K RAM) from Educalc in 1995. The HP16C emulator package loaded into it case MODE menus to lock up (probably because of only 32K RAM). The same HP16C emulator causes no such problems in my HP48GX. I would like to get an HP48G+ and PC Connectivity kit in the future, and plan it to be from Calcpro. Good luck!
