Re: hp 11 c Message #2 Posted by Vieira, Luiz C. (Brazil) on 16 Oct 2001, 12:06 a.m., in response to message #1 by larry schofield
Hello, Larry.
Let me know: do you get an Error 3 when running the [ON] [X] selftest? This is strange... I have only seen Error 9 when running the selftest. Error 3 is related to memory access.
Please, press [g] (and release) then [MEM] (and mantain pressed); you should see something like:
P-nn r-v or P-nn r-.v
where nn is the number of lines of program available before another register is converted into 7 program lines, and v (or .v) is the next register to be converted, if so.
If you press [g] [MEM] (keep [MEM] pressed) and v is 1, so there are only two registers available: 0 and 1. nn will be in the range 00 to 06.
When memory is cleared, [g] [MEM] should result in
P-63 r-.9 (if I am not wrong; I once had an HP11C, now I own an HP15C, that shows more information with [g] [MEM])
If you wnat to clear memory, the sequence is [ON] [-]; [ON] [X] just runs the selftest.
