Re: HP-21/25C Message #3 Posted by Ion Abraham (New Mexico USA) on 8 Oct 2001, 9:51 a.m., in response to message #1 by Reed Jones
Reed and others,
I can confirm the display setting solution (DSP period) and as to the contact to the battery pack, well, I can think of two things. Either you need to clean the battery surface contacts, that is, maybe when the battery is inserted all the way it makes contact in a bad spot on the batteries.
The other option is that the battery pack was rebuilt badly, and is somewhat thicker now than it used to be. Look at the seam under the back of the pack and see if that looks OK.
I also have a question that may be old news for some of you. Is there a list of which part no. charger goes with which calculator? For example, there seem to be two chargers whose connectors fit the 21's and 25's, the 82026 and the 82041, but I don't think they actually ought to be interchanged.
Best regards,
Ion Abraham
Albuquerque, New Mexico
P.S. Reed, if you would like to sell trade the 25C for 41C items, I may be interested. You can contact me directly at the indicated email address.
