NiCad charger for N cells Message #10 Posted by Brian on 23 Oct 2001, 11:47 p.m., in response to message #9 by db(martinez,california)
Don't charge batteries in parallel. Charge as two in series or four in
series or individually. If you are charging NiCad N cells, limit the
charging current to about C/5 or 30 mA ( for 150 mAh N cells ). This
charging current is the same if you have one or more NiCad N cells in
series.
Here's a good NiCad charger circuit link:
http://www.dprg.org/nicad_charger.html
