Re: HP 49G HELP!!!! Message #4 Posted by Vieira, Luiz C. (Brazil) on 4 Oct 2001, 8:21 a.m., in response to message #1 by JAIME RUVALCABA
Hello;
Not to be widely affirmed, but one must consider that there is always a hidden ´X´ variable when this comes to happen. I once had big troubles when I decided to use a variable which name was associated with a library object; I did not remember that. Mam, I had to delete each reference to the variable after removing the library, cause the variable name was substituted for the XLIB number. Big mass.
Anyway, just to complete Mr. Duel´s answer, if you are in a directory, the so called ´X´ variable will cause this trouble if it is located in any upper directory till Home; say, if you are located in the path
HOME - WORK - MINE
the ´X´ variable may be located in any of them and it might be removed in all occurrences.
(Jaime; where are you?)
