Re: HP-41C flex circuit problems Message #4 Posted by Vieira, Luiz C. (Brazil) on 1 Oct 2001, 4:05 a.m., in response to message #1 by Brian
Hello.
I saw a post at Classified Ads where one was selling a sort of 41`s Battery/IO mount (20, if I am not wrong). If I am in USA and I am lucky enough, they are already with me, but I'm in Brazil.
I also have a Bat/IO mount with part of the flex already destroyed by corrosion and I thought about how to rebuild it, since I have no chance to repair the flex itself. I will try a slice of PCB with the copper trails in the same alignment (easy, cause they are standard size). As only two of them are devoted to the batteries, one side will be fully soldered to the remaining flex, and the other will have just to soldering points to the battery contacts. In fact, I think that rebuilding the batteries contacts and wiring them to the PCB slice will be better. As soon as I have something, I'm sending some material (even photos).
All of this to tell I didn't get success repairing the Bat/IO mount... Is there any lab in USA that would produce just that flex for selling? I think a lot of people would buy it.
