Re: HP-19C Message #3 Posted by Tony Duell (UK) on 6 Sept 2001, 8:45 p.m., in response to message #1 by Randy Dickinson
Yes, to rebuild a battery pack just use new NiCd cells and the original terminal contacts, plastic housing and so on (as appropriate).
HP machines with 2 pin chargers (Woodstocks, Spice, Sting, Topcat, etc) generally need the battery pack to be installed and working before you can run them off the charger. In fact with the continuous memory Woodstocks and Spices (HP2xC, HP3xC), connecting the charger without a good battery
will damage some of the chips. I hope the 19C is not like that, but I've never been lucky enough to investigate one.
The exceptions to that are the 71B (where the AC adapter is not used as a charger anyway, just as a PSU) and the 75 (which is documented as working without a battery in place). For the models with 3 pin chargers (35, 45, 55, 65, 67, 70,80), if there is no card reader then it's
safe to run them without a battery, and the machine will work fine (the battery is disconnected when the charger is plugged in). If there is a card reader (65, 67)
then you can burn out the card reader sense amplifier chip if you connect a charger without a good battery pack in place.
I must admit I normally test machines using an adjustable bench PSU set to the appropriate voltage (1.3V per NICd cell or thereabouts) connected to the battery contacts without the pack in place.
That's safe for the machine and it means I can test machines even if I don't have a good battery pack to hand. But it
also means getting a bench PSU and they are not that cheap.
