Re: hp 15c - storage problem Message #2 Posted by Ex-PPC member on 5 Sept 2001, 12:08 p.m., in response to message #1 by Paul Shirley
On the HP-15C, only three registers are available
at all times, namely R0 and R1 (used for matrix operations)
and RI (used for some indirect operations).
The most likely cause for the rest of the registers
to be unavailable would be an improper memory allocation.
I suggest you try to reset the machine, by turning
it off, then press the minus (-) key and, without releasing
it, pressing the ON key and releasing both. This should
clear the machine and show "PR ERROR" on the display.
Then, try again to store anything in, say, R2. If
it doesn't work, maybe your machine needs service.
Hope it helps.
