Re: HP-33E Parts Message #3 Posted by Tony Duell (UK) on 5 Sept 2001, 7:07 p.m., in response to message #2 by gilpetri
Sure you can use normal wire. That's what the ribbon cable I used is -- 3 plastic-covered wires in a ribbon. It's a piece of the same
cable that I use to make floppy drive cables, IDE cables, SCSI cables, and so on.
You could use individual wires, but the ribbon cable is neater and easier to handle.
