Re: HP-33E Parts Message #3 Posted by Tony Duell (UK) on 3 Sept 2001, 1:48 p.m., in response to message #2 by Ron Ross
Just a short comment. AFAIK, the PSU board/flexiprint cable is the same on all HP3xE models,
but the one for HP3xC models is different (it provides the standby supply to the RAM chips). So be careful which machine you raid for parts.
In theory it's the same on old-construction (clamped) and new-construction (soldered) machines, but
it's difficult to desolder the flexiprint in a new type of machine without damaging it. So you probably want to look for the old type of machine.
Incidentally, what's weong with your existing unit? Unless it's totally missing, these units can often be repaired (I've done it), even if the flexiprint ribbon to the battery contacts is torn, for example.
