HP41CX automatic shutdown Message #1 Posted by Nenad Vulic (Croatia) on 28 Aug 2001, 6:16 a.m.
I have a problem with the automatic shutdown. The machine automatically turns off after 1 minute of inactivity. The manual says it should be 10 minutes.
If I execute ON function the machine does not turn off any more until the next press of the "on" button (ie, switching it off). This is normal.
Any ideas about the cause and the solution? Is it possible to give the machine an instruction about this inactivity switch off time, or the default value of 10 minutes cannot be changed.
Thanks,
