Re: HP 41CV Defect Battery Pack - Correction Message #3 Posted by Vieira, Luiz C. on 27 Aug 2001, 11:41 a.m., in response to message #2 by Vieira, Luiz C.
I thought your pack was the Rechargeable Battery Pack; you have a Battery Holder with a broken spring, right?
This way, have you thought about another spring? The ones used in the battery holder do mot have special material, just an special shape. There is always a way to solder two springs (some IR controlers use spring-shaped contacts about the size and shape of the ones used inthe 41), you just have to find someone to do it.
Sorry if I get confused with the batteries´ pack .
