Re: Hi, HP48 users! I appreciate it if someone could help me to convert a 86*64 GROB to 131*64 GROB . Message #3 Posted by Raymond Hellstern on 14 Aug 2001, 5:07 p.m., in response to message #1 by Tal
if I got you right,
the solution will be trivial.
Place the 86*64 GROB on stack level 1,
go into the Graph mode (cursor key left),
blank the area if there's something in.
move the crosshair to the upper left corner,
press the EDIT menu key, press the NXT key twice,
then press the REPL key.
After that, press the MARK key on the previous menu page.
then, move the crosshair to the lower right corner,
the display will shift up some pixel rows.
Then press SUB.
The result should be a 131*64 GROB on the stack,
containing your GROB data.
(hope it works, I only did it from memory)
Raymond
