Re: *.raw files Message #3 Posted by Michael Tjebben on 18 July 2001, 9:53 p.m., in response to message #2 by Tony Duell
Stephan-
If you're looking for a DOS utility which will convert programs between .raw and .lif and .txt and .p41 and .bin formats (a user code compiler/de-compiler as Tony spoke of), go to Warren Furlow's wonderful site and download both the
dos compiler/decompiler (hp41uz.zip) and the Windows GUI (if you want an easy "front-end" for the compiler/decompiler).
The links for both are:
http://doc.hp41.org/Doc/HP41/Download/Hp41uc.zip
http://doc.hp41.org/Doc/HP41/Download/Win41uc.zip
To use the GUI, hp41uc.exe in the same directory as win41uc.exe, because the GUI front-end uses that DOS program to do the actual compilation/de-compilation.
Consider ordering Warren's CD: It's GREAT!
Hope this helps!
-Mike
p.s. If you need the LIFUTIL, that's also at Warren's site:
http://doc.hp41.org/Doc/HP41/Download/LIFUTIL.zip
