Re: HP 41C or HP 41CV Message #5 Posted by Tony Duell on 14 July 2001, 3:19 p.m., in response to message #4 by Paul Kuebler
It sounds like you've got an HP41CV board in a 41C case. The case is identical between the machines apart from the labels, so electrically that's fine.
I assume there's no extra modules inside (some hackers soldered the PCB from a quad memory module inside an HP41C, effectively turning it into a 41CV).
Assuming it works correctly, I'd just use the extra memory :-)
