Re: Faceplate on 42S Message #4 Posted by Paul Brogger on 23 Mar 2001, 3:51 p.m., in response to message #1 by Per Faltman(Sweden)
I needed a "legend" for the blank (painted black) keyboard of my HP-14B case which holds HP-42S circuitry & display.
I printed the MoHPC's HP-42S image on a color printer, cut it down to only the keyboard portion, laminated it, and taped it in "flip-out" fashion to the back of the calculator (between the rubber feet). Now, to see the calculator keys, I just flip it out, and mentally translate the key functions, using the attached keyboard image. It fits inside the slipcover & everything -- pretty cool.
For a real HP-42S, you might do something similar, printing it to full scale and laminating. Then, cut out the key images with an Exacto knife, and glue to the front of the calculator?
Good luck!
