HP-91 power supply problems Message #1 Posted by Chris Dalla on 15 Feb 2001, 11:48 a.m.
Okay, so here's the thing: I've got this HP-91 that I picked up at the flea market a while back, and it clearly _wants_ to work: Display comes up nice and bright, all the keys respond (too well, in fact: the keybounce is awful), everything's happy. Until I light too many segments of the display. As soon as I do that, the calculator resets (the display goes dark for a moment) and comes back up with 0.00.
I'm pretty sure it's a power supply problem and not some sort of bizarre short in the display module because the reset point is clearly linked to the amount of power being drawn: I can load the display up with 1's, but I can only get about four 8's on the display before it resets. In addition, setting the printer switch to ALL or NORM or pressing one of the buttons that would cause the printer to try and print causes a reset.
Now, having said all that, what I'm ideally hoping to find is a schematic of at least the power supply section of the calculator...at worst, I'd just like to know for sure what the 3-pin semiconductor with the heat sink tab is (since all the other parts in the power supply are discretes, I can just measure the ones that aren't marked to find out what their values are). If anyone can help, I'd be grateful.
-Chris
