Pulled apart the 32E Message #1 Posted by Steve on 9 Feb 2001, 7:33 p.m.
OK, I searched the site...
I removed 2 screws from the 32E, and pulled...
I put it down and re-read the instructions. Thenn I pulled a little harder...
Then I looked again. And closed my eyes. And VERY firmly pulled. CRACK! Still not open.
Take deep breath. Close eyes. Ignore thoughts of breaking the bottom off the calculator. Puuuuuuuuuuuuuuuuuull! CRACK! Ping! open!
(Then I saw how easy it was to put together and repeated the last effort one more time :-(
OK, There seem to be brass and plastic clips, and it looks like this may be one of the variety that have chips just sitting there.
What do I do from here?
Not too much corrosion that I can see at the moment. I'm hoping that I can clean up the contacts inside and it will spring into life.
Are the 3xE series seriously damaged if connected to charger without nicads (or with dead nicads). I don't have a charger, but that may be a cause for an otherwise good looking dead calculator I fear.
