Re: HP 48GX Question Message #4 Posted by mkernal on 18 Jan 2001, 11:00 a.m., in response to message #1 by Dan
If it's not too late, I'd change your order to a 32SII instead of the 12C. The 32SII is the only RPN calculator that can natively operate in fractions "mode". Other than the Divide key, the 12C doesn't have a true fractions mode. Check the specs on HP's calculator webpages.
For more information on this, see the thread named "Program for adding fractions?" in early Dec. 2000.
In this thread, on Dec. 7, 2000, Fred ALBERT (France) said "That's right : the 32SII is able to work with fractions. You just have to activate the FDISP function. One of the restriction is that the denominator must be inferior to 4095. You have different modes of fractions to fix the max value of the denominator (up to 4095 of course). You can fix the denominator too, ...."
Good Luck,
Matt
