Re: How to remove Glue from cases Message #2 Posted by Frank on 6 Dec 2000, 5:18 p.m., in response to message #1 by Tom
WD-40 works well for label gum, silicone spray lube can work as well, suggest washing residue of these off with a bit of dishwashing detergent and water mix making a damp cloth, also keep away from chromed or gold plated plastic. If you need a stronger remover, use Gumout quickly and at your own risk for stronger removal capabilities. Some of the thick and solid (like epoxy) adhesives are easier to shear off to remove the largest part of them rather than starting with a solvent IMHO.
