Re: HP-97 printer noise Message #2 Posted by Erik Wahlin on 4 Nov 2000, 12:37 a.m., in response to message #1 by Peter
Hi Peter,
You might try applying a small amount of WD40 oil to the shaft the the print head slides on. Also the shaft that has a corkscrew thread on it. Also if there is a lot of dust in the printer, it is a good idea to blow it out. Another cause of this problem might be foreign debris in the motor gears.
