Re: Another 75C question Message #3 Posted by Mike Davis on 30 Oct 2000, 11:24 p.m., in response to message #2 by Glynn
Yep! I took about every screw out of the "pod" before I realized that I just had to remove the end 3:-) Pays to look first, I guess.
I guess I really need the CD set to figure out how to use this thing. I got another 75C today. It's mint (the 75 I mean; not a scratch on it). Has a very nice hard leather case too. I took a chance when the seller did not know if it worked. It works 100%.
I had a 75 when they first came out but I don't remember much about how they worked.
The "pod" was one that had AT&T on it instead of the HP label. That sucks. So did the 75D but that paper label came off. The backup module might be some sort of non-volatile memory or just a ROM with some backup s/w maybe; who knows. Might have a battery don't know. The 75 and pod only cost $18 so I guess I can't complain.
I wish there was a command to dump everything known about the 75. Seems like some sort of catalog of all available commands known would be nice. I'd like to know what commands access the "Backup" or whatever that is.
I'll let you know if I figure it out.
