Re: Thinkjet Ink Bladders Message #7 Posted by Kevin FitzGerrell on 23 Aug 2000, 2:30 a.m., in response to message #5 by db
Yes, these use plain paper ink. I was happy with these, although refilling these bladders is not as simple as refilling many of the cartridges that modern ink jet printers use.
I made a quick "google" search on:
51604A refill
and found many other companies offering refill kits and/or bulk ink for this print cartridge, some for substantially less than I had been paying.
I have found the print head good for 10 or more refills if the printer is used heavily, 3-4 if it is used infrequently.
These refills are not for the older thinkjet cartridges designed for use on coated paper - the print head jets are different (or so I have been told).
Hope that helps,
Kevin
