Re: hp42 programming question Message #2 Posted by Menno on 10 Aug 2000, 4:02 a.m., in response to message #1 by paul w
Hi Paul,
If you go to the first program you've made, that'is the one next to "end" in the function/program-line. Delete the line with "end". Then the "end" in the function/program-line will be attachted to your first program. To get a program in between other programs you have to go to the "end" of the program an add "..", This will insert an "end" in the function/program-line. Place a "LBL" before the "end and you can edit it to enter a program.
That should do the trick, though I am not sure. I don't take my 42 to work to avoid the risk of loss of damage, so I cannot try it for you.. When It doesn't work I'll try something at home.
You only use the 42 for 6 programs ? The minimum of programs I have in my 42 is 12-18, it is only limited by the 8 Kb memory. For matrix-calculations I have to leave 2 Kb free
Have Fun
Menno
