Recommendations - Glue to stick plastic back together Message #1 Posted by Steve on 21 July 2000, 10:59 p.m.
I have replaced some nicads in an HP41 nicad pack.
Can anyone suggest a suitable glue to stick it back together with? Other packs I've rebuilt (like the ones in the printer) don't really need to be stuck back together, but the HP41 ones do (quite amusing in a dark sort of way if you don't :-)
I've used some quite permenant adhesives in the past, but since nicads do fail, I'm likely to need to get it open again, so something I can disolve with a solvent is probably best.
What do you use?
