Re: HP41 Strange Behaviour Message #5 Posted by Steve on 27 June 2000, 10:04 a.m., in response to message #4 by Viktor Toth
Check the connections at the display end.
There are about 9 wires (quite stiff) that connect to the display. They are so stiff that they can breag the pad away from the board.
Using a loupe, look at wach one carefully and nudge the wire with a match (or slightly lever it). If the contact at the display end moves, one of three things has happened:
1) the wire has broken free of the solder joint. This is the simplest, just solder it back on again.
2) the wire is still soldered to the pad, but the pad has lifted from the board -- the track is NOT broken. This is almost as simple, use a small dab of nail polish (what! you don't wear nail polish?) on it to hold everything together and prevent the track from breaking.
3) the wire and the pad have seperated from the board, breaking the track. This is a bit more complex because you need to solder to whatever part of the track remains, and reinforce it with nail polish.
This may not be the cause of the fault, but it's worth checking. Typically if fault #1 has happened, some twisting of the case (or even pressure on the ON/USER, or PRGM/ALPHA bars) will change the behaviour.
